Slip yoke
Slip yoke
Postby mitchk » Tue Oct 28, 2014 11:50 am
I need a new slip joint or slip yoke or whatever the technical term is for the rear driveshaft. ive been chasing a vibration for a while that started with bad u-joints and ive narrowed it down to the output shaft bearing on the transfer case and that slip joint in the rear driveshaft. I cant seem to find that slip joint anywhere, I went to a few parts stores and then to the dealership and apparently its discontinued. Anyone know where I might be able to find one or what a good alternative is. I already need to rebuild the transfer case and front hubs so im pretty tight on cash so not looking to get a custom shaft or something like that. thanks, mitch
Daily: 91 d350 727 gear vendors over drive, 3/8 feed line, THD lplp, maxed pump, Denny t 2, timing to head, #366 spring, 60# valve springs, arp studs, 60 horse injectors?(po), THD bahf, s362sxe
Project: 93 w250 5 speed, ground stock pin, #366 spring, 60# valve springs, THD lplp, intercooled compressor non intercooled turbine, diamond eye 4 inch, custom intake, south bend hd single
mitchk
Re: Slip yoke
Postby PToombs » Tue Oct 28, 2014 5:49 pm
Most driveline shops should be able to put a new spline unit in your old shaft. Not going to say it will be cheap, I've never done one to know.
Re: Slip yoke
Postby brandonmgreer » Mon Nov 24, 2014 6:54 pm
X2^^^
Find your local standard tranny shop. Most of them will build as mant transfer cases as transmissions. You may have better luck at a 4x4 or driveshaft shop. find a mom n pop, though. Not someone like 4 wheel parts.
As for price... could be $150 for the yoke, could be 600... depends on the part and availability.
It is a good idea to take your whole shaft for matching, and get it high speed balanced while you have it there.
White/black 92 D250 manual conversion, Pump tweaking is about it right now...
95 CCLB 4X4 5 speed being but back together from a wreck
99 Kenworth W900 flat top, Tuned 500 Detroit, BW 75mm 1.32A/R, 5915 injectors, 13 speed, 3.55's
brandonmgreer
