13 inch flywheel
13 inch flywheel
Postby 92cummins89 » Thu Nov 13, 2014 7:52 pm
Putting a 13 " fly wheel an clutch in I can't remember if I read anything bout having in to shim the starter or not
92cummins89
Re: 13 inch flywheel
Postby ellis93 » Thu Nov 13, 2014 8:03 pm
Our trucks came with a factory 13" Sachs clutch. If it had smaller then it was put in there by someone else.
I don't know about other brands but the south bend I have required no starter mods.
Postby 92cummins89 » Thu Nov 13, 2014 8:24 pm
Why do I see the "upgraded" 12.25 clutches kits to 13 inch
92cummins89
Postby RCCUMMINS89 » Thu Nov 13, 2014 9:08 pm
Because to the vast majority of the world a Cummins was not available until 94. No starter spacer one a single disc.
Postby 92cummins89 » Thu Nov 13, 2014 9:45 pm
So stock flywheel is 13 inch correct ?
92cummins89
Postby RCCUMMINS89 » Thu Nov 13, 2014 9:51 pm
Yes, but we have a lipped flywheel and therefore when getting a new clutch, you will still need a new flywheel
Postby 92cummins89 » Thu Nov 13, 2014 10:17 pm
Ahh any reason why it's lipped ?
92cummins89
Postby txs » Wed Dec 03, 2014 7:30 am
why would you need to replace the flywheel with the clutch, good machine shop can resurface the stepped flywheel, if it needs it. I have seen two different farm tractor flywheels that the pressure plate actually bolts to a raised lip, and they have to set up and grind the same amount off both surfaces. The dodges with the lip use the lip to center the flywheel, my 93 stock was not a 13" it was 12 1/4 with lip, so not all first gens were 13s. the later trucks with the six speeds and 13" clutch had to use a starter spacer because the ring gear on the flywheel was moved to the front of the flywheel. The diameter of the flywheel was increased a half or 3/4 of an inch to accommodate the wider bolt pattern of the later style 13" clutch.
txs
