Truck stopped moving
Postby fxr3 » Fri Jan 09, 2015 7:26 am
Driving down highway- then nothing. Engine runs fine, but like something came disconnected between engine and transmission.
fxr3
Re: Truck stopped moving
Postby ellis93 » Fri Jan 09, 2015 9:52 am
What trans?
Postby fxr3 » Fri Jan 09, 2015 10:49 am
1993 w250 automatic
fxr3
Postby ellis93 » Fri Jan 09, 2015 12:26 pm
Either the converter or forward (classified as the rear clutch in the manual) clutch took a dump. Drop the pan and take a look at what's in the bottom of it.
Postby fatty » Fri Jan 09, 2015 2:56 pm
Stock flexplate finally break? Wouldn't expect it to break on the highway but check it anyways.
Postby cmann250 » Fri Jan 09, 2015 3:37 pm
I'd check the shift linkage before I condemned anything extreme.
Postby dazedandconfused » Fri Jan 09, 2015 5:45 pm
Okay it didn't spring a leak and pump the trans fluid out did it?
Postby fxr3 » Fri Jan 09, 2015 9:42 pm
Collar of torque broke
fxr3
