Speedo is off (a lot!)
Postby Jelmer » Mon Jan 19, 2015 9:30 am
I have a problem with the speedo in my 93 D250. It reads way to much. When going 50mph (GPS) the speedo reads 80mph. I had the speedo rebuild, replaced the sensor and checked the wiring and everythings look fine. The truck has stock size tires and is a stick (Getrag)
Anyone has a sollution?
Greetings from the Netherlands where there are only 2 or 3 1stgens!
93 D250 Cummins, G360, 4" stainless exhaust, BHAF, DennyT stage 2 pin, 3200rpm governor spring, 12cm housing, rest stock.
03 VW Bora 1.6
83 Datsun Laurel 4.5 32v V8
84 Nissan Patrol 2.8i
Jelmer
Re: Speedo is off (a lot!)
Postby ellis93 » Mon Jan 19, 2015 10:50 am
Either the ratio adapter on the trans is bad or not there at all. Ptac sales them.
http://www.transmissioncenter.net/speed ... ____va.htm
Postby little doug » Sat Mar 07, 2015 8:38 pm
I had the same issue with my 91,turns out the gears were swapped in the ratio adapter.I just took it apart and switched them side for side.
93 W250 LE extra cab, 5 speed,warn winch, tach,piro,boost gauges. Gov.spring and fuel pin... Play truck
-91 W350 LE reg cab chassis.exxxxtended 175"wb, banks intercooler,on board air ,5 speed,... Work truck
little doug
