overdrive not engaging
Postby ESC93W350 » Thu Feb 26, 2015 8:45 am
Had to change my IP, before that issue everything was just fine. Since putting the new pump in, my O.D. won't work at all.
Any ideas on what could be causing this? Cruise control works, so I don't think it's a tps problem,but don't know. The only thin connected to the trans that came off, was the linkage.
Any direction is appreciated. Thanks.
Eric
1993 W350LE 4x4 automatic clubcab dually. Banks Power Pack w/wastegated turbo. Starwheel,smoke screw, and fuel pin tweeks. Banks pyro and tach, Isspro boost gauge. GearVendors o/d, BD exhaust brake, Kelderman compuride rear bags, front bags.
ESC93W350
Re: overdrive not engaging
Postby shackwrrr » Mon Mar 02, 2015 6:23 am
How is the adjustment on the throttle valve cable/linkage. That would cause it not to shift into overdrive. And I don't believe that the ecm cares much what the TPS says during cruise. It mostly just looks at VSS and brake/clutch pedal inputs.
1991 w250 RCLB
3 speed auto Non IC truck
shackwrrr
Postby Diesel » Sat Mar 07, 2015 6:18 pm
Most likely your TPS. I'm sure you put it back on correctly so it is indexed correct but try taking it off and put it on indexed a little forward by spinning up and installing.
While its off, cycle the switch a bunch to try and clear off the riding surface inside.
If still nothing give the speed sensor on the tcase a look. They can get loose.
1991.5 D250 Intercooled A518
Diesel
Postby ESC93W350 » Thu Mar 12, 2015 10:46 am
I Have adjusted the tv cable/linkage, checked the tps and don't get any voltage change when moving the throttle. I'll try the re-indexing the tps, but think it may be no good.
Everything was working perfectly until I had to replace the injection pump, but I know when electrical stuff goes, it just goes. Could the line pressure sensor on the cooler line cause this. It shifts fine through the othe gears, just won't engage o.d. at all. So I'm stuck back roading, since 55mph spins me at 2300rpm.
ESC93W350
Postby Diesel » Thu Mar 12, 2015 11:29 am
If no signal out of TPS then I think we have the answer. There is a "low buck" tps option thats $35-40 instead of the $250 oem one. I believe it will be a little more expensive if you get a Mopar low buck sensor but probably worth it.
Diesel
Postby ESC93W350 » Thu Mar 12, 2015 12:51 pm
Anyone have a link to the low buck option? It would be appreciated.
Thanks,
Eric
ESC93W350
Postby Diesel » Thu Mar 12, 2015 7:12 pm
Diesel
