CumminsPower59 wrote:Wheel bearings can take a lot of abuse, so unless they are trashed, they should be ok. The wheel seals are easily replaced though. When you replace the seal, repack the wheel bearings with grease or prelube them with gear oil. I repack the bearings, but everyone does it their own way
BC847 wrote:Be sure to closely inspect all components of the axle vent. Un-plug all that required.
