Oil in brake drums
Oil in brake drums
Postby Jelmer » Tue Mar 24, 2015 1:20 am
I've noticed some oil in the brake drums yesterday so I figured the seals must be leaking and maybe the wheel bearings are shot. Where are these seal located? Near the diff of near the wheels?
Greetings from the Netherlands where there are only 2 or 3 1stgens!
93 D250 Cummins, G360, 4" stainless exhaust, BHAF, DennyT stage 2 pin, 3200rpm governor spring, 12cm housing, rest stock.
03 VW Bora 1.6
83 Datsun Laurel 4.5 32v V8
84 Nissan Patrol 2.8i
Jelmer
Re: Oil in brake drums
Postby Philip » Tue Mar 24, 2015 5:57 am
They are located in the axle hub.
Postby CumminsPower59 » Wed Mar 25, 2015 7:03 am
Wheel bearings can take a lot of abuse, so unless they are trashed, they should be ok. The wheel seals are easily replaced though. When you replace the seal, repack the wheel bearings with grease or prelube them with gear oil. I repack the bearings, but everyone does it their own way ;)
Postby thrashingcows » Wed Mar 25, 2015 6:43 pm
CumminsPower59 wrote:Wheel bearings can take a lot of abuse, so unless they are trashed, they should be ok. The wheel seals are easily replaced though. When you replace the seal, repack the wheel bearings with grease or prelube them with gear oil. I repack the bearings, but everyone does it their own way ;)
I used to repack the bearings with grease, but have since stopped. I had the grease come out and form a bit of a "dam" in the hub and starve a rear bearing of proper lubrication. Now I soak the bearings in a container of gear oil and toss them in just before I install the hub. I also tip the hub backwards slightly and fill the hub with as much oil as possible before I slip it over the spindle. Been great so far!
thrashingcows
Postby BobS » Wed Apr 01, 2015 10:48 am
I used a skim coating of wheel bearing grease when I did mine. No issues in the last 50K miles since they were done.
BobS
91.5 W250 NV4500 Conversion
89 D350 Stock
BobS
Postby cougar » Sat Apr 04, 2015 11:33 am
When you have it off, take a serious close look at the hub. I kept replacing seals on my 91 and never stopped the leak. Turned out the hub was cracked outboard of the sealing surface. Replaced the hub and problem solved.
01 2500 "the work truck".
cougar
Postby BC847 » Sat Apr 04, 2015 2:09 pm
Be sure to closely inspect all components of the axle vent. Un-plug all that required.
Postby Douglas » Fri Sep 04, 2015 11:03 am
BC847 wrote:Be sure to closely inspect all components of the axle vent. Un-plug all that required.
Plugged vent components will allow the axle to pressurize itself and then leaks are guaranteed.
true that!
Inspect the axle journals too; I got a 3.08 Power-Lok rear and the journals were waaay pitted and grooved. Drove on a speedi-sleeve( there are two sizes of journals, measure diameter before ordering ), and have had no issues. IIRC the bolted axle have a different one from the studded ones....is usual that later ones are bolted, and the earlier studded take the 3" speedi sleeve to repair the journal.
cheers,
Douglas
1991 D250, 727 and 16cm H1C.
Douglas
