No OD, wait to start + water in fuel lights on/flashing
Postby ofelas » Tue May 05, 2015 6:24 am
Hi,
Does this randomly. Grid heaters work as does the WIF sensor.
Overdrive off switch clicks & lights as usual, but no OD sometimes.
When this happens, the water in fuel & wait to start lamps light steadily & sometimes flash.
Its a 91.5 with no crank sensor or tach plug, and an ECM with an external regulator.
Truck doesn't have AC or cruise.
Thx!
R12 = liquid bilit
ofelas
Re: No OD, wait to start + water in fuel lights on/flashing
Postby 93cummins89 » Tue May 05, 2015 6:42 am
Check fuses then the wires. All the lights on the message center are tied into a lot of other things and the factory splices are not very well done and could be rubbing on metal and grounding out. I found this out because I'm eliminating my ecm and everything it controls including message center
93cummins89
Postby ofelas » Sun Jun 28, 2015 2:41 pm
Hey bud thx went through all that.
Fried ECM - not repairable.
Running pin 55 & pin 4 to ground off the ECM plug temporarily for OD & speedo while I try to find a good 91.5 core.
If not, ECM delete it is!
R12 = liquid bilit
ofelas
Postby 93cummins89 » Mon Jun 29, 2015 1:01 pm
delete is the way i went. not sure if mine was bad or not but i wasnt going to pay and wait 4 weeks to find out. and fyi if u go through urs like i did mine(total rewire and moving fuses to behind the battery) buy urself a painless or bare bones kit. im thinking about buying one even after i got all the parts and new fuse blocks for mine
93cummins89
Users browsing this forum: No registered users and 53 guests
