727 tailshaft bearing help
Postby panhead » Sat May 09, 2015 7:12 am
Hey all. Having a major issue locating a new tailshaft bearing for my 90 d250. All avenues I've explored locally, and on web have resulted in "no longer available". The bearing in question has a MRC 207sg13 part#. It's dimensions are. i.d. 31.43mm o.d. 72.06mm with a thickness of 17.0mm
In inches- 1.235 I.d. 2.836 o.d. 0.670 thickness. Anybody with any help would be appreciated. Thanks
panhead
Re: 727 tailshaft bearing help
Postby thrashingcows » Sat May 09, 2015 8:33 am
Is this the bushing "inside" the tailshaft housing?
thrashingcows
Postby panhead » Sat May 09, 2015 10:47 am
No. It is the roller ball bearing inside tailshaft housing. This is a bolt on yoke 727. No bushing. It seems as though I've ended up with a stepchild as far as the output shaft diam. The common would be 1.35ish". Chrysler vintage parts told me their last 1.23" was sold 3 yrs ago, and nobody has made a run of em since.
panhead
Postby matthewh » Sat May 09, 2015 5:28 pm
Check with ZBag in Minnesota, or Detroit Ball Bearing, the first company specializing in transmissions, tcase's and axles. The second company specializing in all sorts of bearings, especially odd ball, hard to find bearings.
matthewh
Postby panhead » Sun May 10, 2015 7:12 am
Hey, thanks for a couple new names to try. I will be on it, and will post up the solution. Again, the help and info is appreciated. Thanks.
panhead
Postby matthewh » Sun May 10, 2015 8:28 am
Detroit Ball Bearing may have changed names to Applied Industrial Technologies.
Where in the U.P. You located? I'm an hour southwest of the Mackinaw Bridge
matthewh
Postby panhead » Sun May 10, 2015 10:48 am
I'm up in the Houghton area.
panhead
Postby panhead » Tue May 12, 2015 6:24 pm
Bearing update. None found through exhaustive searching. Machined machined bushing to fit inner race of a 33 mm I.d. Bearing. Installed, buttoned up, and rolling.
panhead
