OEM Getrag 5 speed shifter assembly questions and needed
Postby 888 » Mon Aug 17, 2015 12:07 pm
I am getting a first gen as a father and son project with my youngest and it has a newly rebuilt Getrag 5 speed manual transmission. Along the way, the 5 speed shifter lever and boot etc were lost and there is something less than attractive that has been fabbed up. Are there any second gen trucks that have that same shift lever assembly and were they the same between the different manual transmissions offered in the 12 valves (I believe an NV and the Getrag)?
Anyone happen to have a parts truck with an extra shifter assembly that would fit? Thanks in advance, Joe
93 Dodge D-350 Cummins Xcab DRW - completely stock
89 Dodge D-250 Cummins SRW 5 speed father and son project
84 Dodge D-100 5 speed slant 6
92 Dodge D-350 Cummins DRW 5 speed
others....
888
Re: OEM Getrag 5 speed shifter assembly questions and needed
Postby PToombs » Mon Aug 17, 2015 4:28 pm
If you have the screw on shift lever then one from a 2nd gen will work. I have one in mine from a gasser, it is about 3 inches shorter than the original so the throw is a little shorter. I had one from a Dakota, but it was a little too short, I had to lean over for 5th gear. :lol:
Postby RumbleFish » Mon Aug 17, 2015 7:15 pm
I think i have an oem boot if you cant find anything else to work
Postby 888 » Wed Aug 19, 2015 5:31 am
Thanks for the replies. I just got the truck home last night so let me see what I've got to work with.
others....
888
