Pilot bearing or bushing
Postby 1992gen1_fan » Wed Aug 19, 2015 4:58 am
Hello, I have the transmission and everything out of the truck so I can fix the rear main seal and pan seal ect.. I haven't pulled the clutch off yet but I figured while the clutch is off I'd replace the pilot bushing while its appart.
This is my first time working on a clutch, I went to order a new pilot bushing and noticed there was a pilot bearing (needle bearing) and a pilot bushing (Brass or bronz) bushing available on rock auto.
Do these have both or just one or the other? And if they're interchangeable, which one is better?
Thanks
1992gen1_fan
Re: Pilot bearing or bushing
Postby ellis93 » Wed Aug 19, 2015 5:19 am
Never fooled with a bearing in the flywheel,it's always been a bushing.....bronze. Soak it in oil the night before to let it pull in some lube.
The aftermarket flywheels like south bend offers,has a seal ball bearing pilot.....those are really nice.
Postby 1992gen1_fan » Wed Aug 19, 2015 5:30 am
Ok, I'll get a bronze bushing and soak it in oil then, thanks 8)
1992gen1_fan
Postby 1992gen1_fan » Wed Aug 19, 2015 12:50 pm
Bought a bronze pilot bushing, I'll put it in oil until I get ready to install it to make sure it soaks in :D
1992gen1_fan
Postby dpuckett » Tue Sep 29, 2015 4:40 pm
I dont think the bushing and braring are interchangeable. I have a sealed ball bearing pilot from South Bend. Had to get my flywheel machined to fit, but it has done its job.
Postby 1992gen1_fan » Wed Sep 30, 2015 5:15 am
Yea I see now that it just depends on the flywheel to what pilot bearing or bushing you have. Got the new bushing installed, old one was about gone :shock:
1992gen1_fan
1992gen1_fan
Postby PToombs » Wed Sep 30, 2015 1:56 pm
I put in a needle bearing instead of a bushing, it was the same size, no machining required. Only the roller bearings need the flywheel opened up.
Postby 1992gen1_fan » Wed Sep 30, 2015 3:27 pm
Well maybe if I ever have it appart again (hopefully not for a while) I'll try a needle bearing instead :mrgreen:
1992gen1_fan
Postby thrashingcows » Sun Oct 04, 2015 1:17 pm
I personally don't much care for the bearings. What I don't like is that if the bearing begins to fail the hardened surface will start to cut into you input shaft....seen this happen more then once. ;) But with the bronze bushing, it the bushing that wears out, and the input shaft is not damaged.
thrashingcows
Postby BobS » Tue Oct 06, 2015 5:53 am
thrashingcows wrote:I personally don't much care for the bearings. What I don't like is that if the bearing begins to fail the hardened surface will start to cut into you input shaft....seen this happen more then once. ;) But with the bronze bushing, it the bushing that wears out, and the input shaft is not damaged.
I also agree with this. The bronze bushing is considered as a wear item. The needle bearing is a run or fail item which also has no means to relubricate unless you remove the transmission. With the past history mentioned on here of the common slight mis alignment of the Getrag transmission to bellhousing to engine adapter/flywheel housing I would rather replace a $2 bronze bushing rather than trying to locate a new replacement transmission input shaft.
BobS
91.5 W250 NV4500 Conversion
89 D350 Stock
BobS
Postby 1992gen1_fan » Tue Oct 06, 2015 5:41 pm
Good point. The bushing is less parts to come appart and get into the clutch also.
1992gen1_fan
