Torque Converter
Torque Converter
Postby ggreenall90 » Mon Sep 07, 2015 1:01 pm
Wondering what a good torque converter upgrade will be. Truck is stock with exception of HVLP lift pump. Stock one seems to be okay but thinking I should upgrade it. Truck has 138k miles.
ggreenall90
Re: Torque Converter
Postby oldestof11 » Mon Sep 07, 2015 3:23 pm
I would recommend:
Suncoast
Diesel Performance Converters
Spec-Rite
Postby Sutter1stgen » Mon Sep 07, 2015 9:36 pm
I currently run a Specrite. My old boss runs a Suncoast. You can't go wrong with ether one. I feel the Suncoast has a higher flare stall, whereas they both have about the same braking stall.
Eric
Sutter1stgen
Postby ofelas » Fri Apr 08, 2016 3:21 pm
TCS Products out of BC, Canada, super cool to order from, threw it in yesterday with a flex plate & some small parts from TCS Products.
Bilit, naturally ;-)
http://www.tcsproducts.com
R12 = liquid bilit
ofelas
Return to Transmission
