Getrag transfer case adapter seal help
Postby Dodgew350 » Mon Oct 12, 2015 7:28 pm
I am looking for the seal for the adapter to my transfer case it's a 1991.5 dodge w350 with the getrag, none of the auto parts stores can find it- it's the part of the adapter that butts up to the transmission and there is a seal in the adapter that goes over the output shaft of the transmission and I cannot find it anywhere any suggestions would be good even a part number if someone has one?
Dodgew350
Re: Getrag transfer case adapter seal help
Postby 1992gen1_fan » Mon Oct 12, 2015 9:44 pm
E2132 is the number on the one I just replaced. It came from Standard Transmission. If the autopart store can't get it (they should be able to), give them try.
1992gen1_fan
Postby Dodgew350 » Tue Oct 13, 2015 7:35 pm
Thanks that what I needed. P.S I just joined this site is awesome !
Dodgew350
