Starter issues South Bend clutch flywheel
Postby Dodgew350 » Tue Oct 13, 2015 7:24 pm
So I installed a South Bend clutch kit with the flywheel upgrade everything went together beautiful but then I noticed the starter is in to far because of the different offset on the South Bend on the South Bend flywheel upgrade, so do I need a second GEN starter for the 13" flywheel what have other people done, do I need a second GEN starter, or has anyone put washes on it to bring it out?
Dodgew350
Re: Starter issues South Bend clutch flywheel
Postby dazedandconfused » Wed Oct 14, 2015 12:35 am
They make a starter spacer/shim that is needed with some.
