518 band adjustment for 2nd
Re: 518 band adjustment for 2nd
Postby Philip » Mon Oct 31, 2016 4:25 pm
Waiting for the update. Hope it works this time. :mrgreen:
Postby 1STGENFARMBOY » Tue Nov 01, 2016 8:06 pm
Put 6 miles on the trans, sounds good, pulls very good, but need to adjust the TV cable, it shifts into 3rd around 25mph, after letting it go through the gears 9-10 times I put a little fuel to her after O/D hit......the fun stopped when I popped a cooler boot....at 42psi :shock:
may need to take it easy or turn the fuel down a little....not in the mood for a HG change right now.
driving to work in the morning, will update after having it hooked to the camper this weekend.
thanks for your help Philip.....you are a good man.
Dar
Postby dazedandconfused » Wed Nov 02, 2016 4:26 am
Glad to hear you got it going
Postby Philip » Wed Nov 02, 2016 12:08 pm
:jumpsmile:
glad to hear you got it going.
Postby thrashingcows » Thu Nov 03, 2016 11:08 pm
Glad it's back together and moving under it's own power....hope you get many trouble free miles out it! :mrgreen:
thrashingcows
Postby 1STGENFARMBOY » Wed Nov 09, 2016 2:08 pm
trans tows like a beast, builds almost no heat, we will see how long she goes.
Postby thrashingcows » Fri Nov 11, 2016 1:54 pm
1STGENFARMBOY wrote:trans tows like a beast, builds almost no heat, we will see how long she goes.
Nice!!! :cheers:
thrashingcows
Postby dazedandconfused » Fri Jan 06, 2017 9:04 am
Now that some time has past how are you liking your trans?
Postby 1STGENFARMBOY » Tue Feb 14, 2017 8:39 am
I am getting close to the first filter and fluid change, I am going to adjust it a little when i have the pan off, it is doing fine, the shift points are still a little off but over all it is nice, I havent noticed any MPG gain which sucks but maybe when we get out of the crapy winter fuel blend it will help.
