Temperature gauge
Temperature gauge
Postby Dirty Luther » Sat Apr 23, 2016 5:25 am
Last night on the way home running a steady 65 mph on a cool night my temperature gauge started acting funny going from cold to hot and back down repeatedly. When I arrived at home and turned the key off the temperature gauge pegged itself on the hot side although the engine didn't seem to be that hot.. The next day I drove it a few miles it did the same thing. But this time when I got back I could hear coolant gurgling in the radiator . Drove it again a few days later and everything seemed to work as it should... And now a week later it's doing it again???
Dirty Luther
Re: Temperature gauge
Postby Philip » Sat Apr 23, 2016 6:04 am
I would replace the thermostat. Then see what it does.
Postby justin.loehlein » Mon Apr 25, 2016 3:12 am
Check the coolant level. If there's a bunch of air in the system, the gauge will jump around as it gets exposed to the coolant and then air.
1990 D250, 5 speed
1993 W350 waiting to be restored
justin.loehlein
