NP 205 yoke question
Postby Richie O » Wed Jul 20, 2016 5:50 pm
I was under the 92 checking for any issues. I noticed the rear yoke on the np does have a little movement. The shaft is tight on the yoke so I guess the movement is in a bearing. Its barely noticeable, yet can feel a little. Can I just re torque the nut to reload the bearing some?? Is that how the bearings are loaded? Truck is just under 190k miles, but hard miles :D
Re: NP 205 yoke question
Postby Philip » Wed Jul 20, 2016 8:19 pm
That is a roller bearing. You will not get all the movement out of it. If the movement isn't enough to wipe the seal out your good.
Postby Richie O » Thu Jul 21, 2016 11:25 am
Philip wrote:That is a roller bearing. You will not get all the movement out of it. If the movement isn't enough to wipe the seal out your good.
Nope, not leaking at the seal. Sweet Philip,,,, thanks. :D
Return to Transmission
