4x4 light always on
4x4 light always on
Postby fxr3 » Wed Aug 31, 2016 12:38 am
93 w250 diesel. I understand part is hard to find. Can I just disconnect wire somewhere to shut off light permanently? Thanks in advance.
fxr3
Re: 4x4 light always on
Postby DodgeFreak » Wed Aug 31, 2016 1:40 pm
if you pull the dash surround you can just pull the bulb out.
Postby BC847 » Wed Aug 31, 2016 2:48 pm
You might consider simply unplugging the switch on the top/passenger's side of the transfer-case and see if that rectifies the problem. If not, you've a wiring issue.
Postby fxr3 » Wed Aug 31, 2016 6:47 pm
I'll try the dash light thing first. Im an expert at taking that apart- trying to put brighter lights in speedo area. That was 10 years ago, and have been tempted to try again with todays modern bulbs. Thanks.
fxr3
