No more porcrastinating
Postby cougar » Sat Oct 01, 2016 8:43 am
The 518 went yesterday without warning. So the 47RH swap has to begin. Got everything except how much to shorten the forward section of my rear drive shaft.
01 2500 "the work truck".
cougar
Re: No more porcrastinating
Postby stuffy » Sat Oct 01, 2016 9:13 am
Some people don't shorten theirs but since the adaptor plate is 1 inch longer it should be shortened 1 inch. The case is the same
92 w250
Silver Bullet, pump maxed, full manual 47re, 5x18s, Hungry Diesel piston pump
stuffy
Postby cougar » Sun Oct 02, 2016 8:48 am
My center support bracket as well as the transmission mount plate is already at the end of their adjustment slots, so shortening the forward shaft is a have to. Really don't want to guess on this one. I'd l to get the center support bearing back in the middle or all the way forward in the slots.
cougar
Postby Philip » Mon Oct 03, 2016 8:42 pm
Slide the shaft into the trans. Set the slide yoke about 2/3's of the way in. Hold the shaft up to the carrier bearing support. Measure the difference from bearing bracket to mount.
Postby cougar » Wed Oct 12, 2016 10:25 am
Well, the shop has the transmission all hooked up except the drive lines. They are getting my short shaft shortened. In the mean time I have modified my OD switch circuit to accommodate the CompShift's different wiring. All I had to do is change the relay on the board and the external wiring a little.
cougar
Postby cougar » Tue Oct 18, 2016 4:05 pm
The transmission is defective. Just my luck. The overhauler won't warranty it. Just my luck.
cougar
Postby ellis93 » Tue Oct 18, 2016 6:28 pm
Dang that blows!
Postby DodgeFreak » Wed Oct 19, 2016 1:16 pm
What is defective about it?
Postby cougar » Thu Oct 20, 2016 4:31 pm
It won't shift. All I have is 1st and reverse. May be valve body, may be governor. I have a neighbor that is going to look at it for me.
cougar
Postby cougar » Fri Nov 11, 2016 12:04 pm
Neighbor finally got it in his shop. Low to no governor pressure. The transmission comes out next week for tear down.
cougar
Postby cougar » Sat Nov 19, 2016 9:17 am
The transmission was torn down Thursday. The governor bore was badly pitted letting a lot of fluid to leak past the seals. Easy fix though, there is a repair sleeve for it. There was also a snap ring missing that wasn't helping. Otherwise thing looked good. While he has it apart I'm going to have him upgrade the usual problematic parts and install the shift kit.
cougar
Postby cougar » Fri Jan 06, 2017 11:50 am
It got worse. After repairing the governor he started on the throttle body that I wanted upgraded. Problems with the throttle body. Then he noticed other problems and took the transmission completely apart. At this point I would have been better off having him overhaul my $300 core instead of buying that $1,650 off the shelf unit. It literally looks like it was put together with discarded hard parts and new soft parts, all of which I will now have to replace. All totaled, I'll have about $6G in just the transmission not including the R&R and all the conversion fab work.
cougar
Postby BC847 » Fri Jan 06, 2017 2:07 pm
I think you should "Revisit" the warranty thing with the builder. Be sure to include pics.
Postby ellis93 » Fri Jan 06, 2017 3:07 pm
What BC said^^^^^. To pay that much for a "built" unit and have that much wrong, that's some bs.
Postby cougar » Sun Jan 08, 2017 10:38 am
I have filed complaints, but the business is up for sale. So I placed "comments" on his adds warning prospective buyers what liabilities they could face.
cougar
