47RH parts help
47RH parts help
Postby cougar » Tue Feb 14, 2017 9:13 am
My transmission build is being held up by 1 small part. There is a retaining washer that holds the valve in place in the governor. It is approx 1.130 OD x .667 ID x .020 thick made out of hardened steel. Mine is broke in 2 and the transmission re builder can't find a replacement. Anyone know where I can get one ASAP?
01 2500 "the work truck".
cougar
Re: 47RH parts help
Postby cougar » Tue Feb 14, 2017 5:37 pm
Never mind, turns out the shop sold me a messed up V 10 trans instead of a messed up diesel trans.all necessary parts are being replaced.
cougar
Re: 47RH parts help
Postby PToombs » Thu Feb 16, 2017 4:00 pm
Boy you have bad luck! Hope things go better for you now!
Re: 47RH parts help
Postby cougar » Fri Feb 17, 2017 10:05 am
I'm hopping he will have it back together today so I can start wiring the Compushift this weekend.
cougar
