Rear disc brakes
Rear disc brakes
Postby 92cummins89 » Mon Mar 12, 2018 8:23 pm
Found an axle out of an 02 dodge with disc brakes for a good deal what all is invoked in swapping to a disc rear end
92cummins89
Re: Rear disc brakes
Postby Donkey Kong » Wed May 23, 2018 12:20 pm
I put rear discs on my Dana 70 and had to modify the e-brake connections. Not sure if your E-brake cables and lengths will match up??
Darth Cummins 93 CC W250 NV4500 HX35 350hp 37s 1.5T leafs...its stiff
Donkey Kong
Postby Donkey Kong » Wed Jun 20, 2018 3:43 pm
I also recommend bypassing the ABS valve above the rear axle to give more flow due to the piston size difference verus rear wheel cylinders
Donkey Kong
Postby bensol64 » Fri Oct 25, 2019 12:50 am
I'm planning to upgrade mine also and I'm looking for a complete kit.
bensol64
Postby Philip » Fri Oct 25, 2019 8:42 am
Going to need to do something about the master cylinder. The stock M/C will not flow the fluid for the disk requirements.
