Time to rebuild or replace an A518
Postby gassplant » Mon Sep 17, 2018 10:15 pm
I have a 1992 D350 and the automatic transmission is slipping. I don’t know whether to rebuild or replace it. I want to stay with an automatic. What the difference between a stage 1 and 2? Is there any other automatic transmissions that will work? Thanks
gassplant
Re: Time to rebuild or replace an A518
Postby Donkey Kong » Tue Sep 18, 2018 3:19 pm
What do you plan to do with the truck? A properly built A518 will go a long way, and its cheaper than converting to a 47RH.
Darth Cummins 93 CC W250 NV4500 HX35 350hp 37s 1.5T leafs...its stiff
Donkey Kong
Postby gassplant » Wed Sep 19, 2018 10:55 am
Daily driver and pull a fifth wheel. Camper sometime in the future.
gassplant
Postby dazedandconfused » Wed Sep 19, 2018 6:16 pm
Upgrade to a 47rh you will be much happier.
Postby thrashingcows » Wed Sep 19, 2018 7:12 pm
Just know that there is a bit of extra work and expense with going 47RH, different engine plate adapter and tranny mount/cross member locations, and wring for the lock up and OD, unless you spend some $$$ on a controller assembly.
Personally I would spend some good money on a low stall converter and go with a good high end rebuild, and be money ahead. ;)
thrashingcows
Postby dazedandconfused » Thu Sep 20, 2018 3:01 am
thrashingcows wrote:Personally I would spend some good money on a low stall converter and go with a good high end rebuild, and be money ahead. ;)
I just did this and wish I would have went with the 47rh.
Postby Remps » Thu Sep 20, 2018 5:44 am
My "built" 47rh with a lower than stock stall feels like a slipping mess without the lockup working. Goes like a bat outa hell when you hammer it, but you can't feel the torque of the lower rpms at all. Even moderate acceleration requires shoving my foot into it some, whereas with the lockup, I could just hit the switch and take off, without giving it a bunch of throttle. Those that haven't drove a 1st gen with lock up don't know what you're missing. A second gen starter is required for the swap as well. Stock shift linkage will work, but will be twisted to the rear somewhat.
Postby ellis93 » Thu Sep 20, 2018 11:47 am
You want the lockup unless you buy a custom (read made specifically for your truck 100%) converter. My vote would be for the 47rh.
Postby Donkey Kong » Thu Sep 20, 2018 7:23 pm
Agree 47RH is a better tranny. Maybe save some $ by pulling one from a wrecked 94-95 2nd gen? I would still get a built A518 and a nice TC.
Donkey Kong
Postby cougar » Sun Sep 23, 2018 9:19 am
viewtopic.php?f=3&t=17584 Read my write up, I'll be happy to answer any questions you might have. After working out the bugs I'm very happy with my conversion.
01 2500 "the work truck".
cougar
