Need help securing lockdown cable to trans
Postby Collers9640 » Mon May 13, 2019 8:24 am
Does anyone have a remedy for securing the kick down cable to the ball stud on the transmission. The white plastic piece that snaps on the ball stud is apparently worn out enough to cause it to pop off
Collers9640
Re: Need help securing lockdown cable to trans
Postby thrashingcows » Thu May 16, 2019 6:22 pm
A couple of Zip ties is all I can think of.
thrashingcows
Postby Collers9640 » Sat May 18, 2019 8:53 am
I don’t think zip ties are gonna work. Hmmmm I can’t believe no one else has had this problem
Collers9640
Postby PToombs » Mon May 20, 2019 4:49 pm
Try a solder gun to melt the edges and push them in to tighten the hole. If you need filler, a white zip tie might work.
