I think my transmission is almost dead
Postby nooblet » Mon Mar 03, 2008 4:12 pm
I put a new clutch in my truck because the old one was slipping, and the drive train was doing some weird things that I thought were possibly clutch problems.
I put the clutch in and it stopped slipping, but most of the problems I was having are still there. I get a real bad vibration at higher speeds. I start noticing it at about 50mph and then the faster I go the more vibration I get. When I let off the throttle the vibration completely stops until I throttle up again. The worst vibration by far is at high rpms in 3rd gear though, which I don't understand at all. When I shift from 2nd to 3rd the truck starts vibrating more and more until about 2800rpms, then the vibration just completely goes away??
Also there is a rattling when the truck is idling in neutral.
There is also a lot more backlash than there should be when accelerating and letting off the throttle.
All of these problems were there before I put my new clutch in, but have gotten MUCH worse since the new clutch. Also, when I pulled my old clutch and flywheel, the throw-out bearing sounded like a bucket of bolts and my pilot bushing came out in several pieces.
What do you guys think is going on? Do I just need to get my tranny rebuilt or do you think its something else?
Give me about another year and I'm going to have a completely rebuilt truck :mad:
Chris
nooblet
Postby PToombs » Mon Mar 03, 2008 5:17 pm
I think I'd be pulling the PTO covers off and checking shaft end play and metal in the trans.
Did you overfill by 1 quart of oil?
Postby oldestof11 » Mon Mar 03, 2008 5:22 pm
Sounds like the 10 bolt in my Suburban. Have a buddy look under the truck while it is in neutral (and turned OFF!) and rock the truck back and forth. The Burb did that and it is the rear-end having about 1/8 turn of play in it :shock: But still held up to full throttle from a dead stop. :lol:
The other thing to check is the U-joints.
Enjoy!
Postby nooblet » Mon Mar 03, 2008 5:36 pm
PToombs wrote:I think I'd be pulling the PTO covers off and checking shaft end play and metal in the trans.
When I put the clutch in I changed the oil. It looked like it did the day I put it in 2 years ago, clean and metal free. I over-fill it by about 1.5 quarts. My Chiltons said to put 10W-30 in it, I figured a little heavier wouldn't hurt, so I put 15W-40. What do you guys use?
When I pull the PTO covers what am I looking for? Just turning stuff in there and seeing how much play everything has? I know almost nothing about the inner-workings of a transmission. :sad:
Chris
nooblet
Postby PToombs » Mon Mar 03, 2008 5:59 pm
I use 15-40 too, "borrow" it from work. ;) Try prying the shafts back and forth, checking for end play. Wouldn't hurt to jack up the truck and rock the wheels and drive shaft, check for play in the diff first. Check the oil in the diff too. Like Jon said, check the u-joints, they can cause vibration too.
Postby 75Dodge » Tue Mar 04, 2008 10:48 am
Have you checked your motor mounts? mine had some terrible problems, violent shaking of the engine... :?
1989 D-250 LE Automatic 150hp at 55mph! 3200K Spring, tweaked pump, H1C/H1E hybrid.
75Dodge
Postby nooblet » Tue Mar 04, 2008 1:36 pm
75Dodge wrote:Have you checked your motor mounts? mine had some terrible problems, violent shaking of the engine... :?
I'm sure it wouldn't hurt one bit to replace the motor mounts and transmission mounts. I highly doubt they've been replaced in the 18 years and 320k miles my truck has been in use. :shock:
I think I'm going to do mounts and U-joints and see what happens, since they probably need to be done anyway.
Chris
nooblet
Postby nooblet » Wed Mar 05, 2008 10:28 pm
So... I went to Carquest and got some U-joints, tranny mounts, and motor mounts. They ended up giving me the wrong U-joints (big surprise) and I wasn't paying enough attention to notice the U-joints they gave me were almost half the size of the 1410's I needed.
So I hop in my truck and off I head to Carquest, when boom, clank clank clank, you guys know the drill I'm sure 8)
Put new U-joints in and all is well... go figure. Good call on the U-joints guys!
It was ironic that I was on my way to Carquest to exchange the U-joints when mine blew up :shock:
Chris
nooblet
Postby Ace » Thu Mar 06, 2008 11:44 am
Looks like a new yoke for the 70 might not be a bad idea now too.
Ace
Postby greasemonkey » Thu Mar 06, 2008 12:08 pm
I just checked my U-joint and there's a little play in it :shock: well, thanks for serving as a warning, I coulda had the same picture to post in the near future!
'93 250 4x4 NV4500, flatbed, club cab, ex brake, pump tweaked, too many new ideas thanks to you guys.
dubbed the "Mexican Mtn Goat"
..if you find yourself in a fair fight you did not properly prepare..
..hot rodders are the original recyclers!..
greasemonkey
Postby cummins king » Thu Mar 06, 2008 1:07 pm
when i bought my truck i could turn the drive shaft 1/4 turn, thats how much play was in my u joint, i still drove it 150miles+ home, and for another 300miles before i changed it, kind of scared me when i took it all apart :shock:
93 4X4 auto
cummins king
Postby gear jammer 91" » Sun Mar 09, 2008 9:24 pm
Some years ago I had a big half ton chev and I was headed to a buddies to change a u-joint that I knew was going out, about a quarter mile from his house I thought I'd stand on it and let him know I was commin, When the trannie down shifted the u-joint blew apart and I ended walking the rest of the way to his house. :lol:
01 LB7
gear jammer 91"
Postby GO OVRIT » Mon Mar 10, 2008 1:36 pm
My cb handle is Driveshaft. I've been through at least a dozen u-joints, a dozen straps, 3 yokes and a couple of shafts on my Jeep. One shaft twisted just like a twizzler. :shock:
GO OVRIT
Postby oldestof11 » Mon Mar 10, 2008 2:10 pm
Wheres my cookie? *crickets*
Ok, I know. I dont get a prize. :(
But when I did my U joints as preventive maintenance, 2 u joints had each 3 caps with nothing but powder in them.
Postby PToombs » Mon Mar 10, 2008 5:14 pm
oldestof11 wrote: 2 u joints had each 3 caps with nothing but powder in them.
Sounds like a lack of maintenance right there! ;) :lol:
