Daniel cast can be welded, at our shop we stick weld cast,but it can be brazed.dpuckett wrote:I have a Getrag with a nice silver-dollar sized hole in the side of the case, near the reverse idler. Apparently what happened, is the pocket bearing gave way, and instead of parking it when it started to make a funny noise, the kid kept driving it. A bearing roller got stuck between the reverse idler and the case, putting a hole in the case. The hole isnt in any area where structural integrity would be comprmised (it isnt like Cade's, where the rear of the case came off). I am having trouble finding a good case to replace it, and am getting antsy to get the truck roadworthy. I have read about heads and blocks being welded and run just fine. It seems that with lots less pressure, a welded patch on a tranny would work as long as it holds fluid. I do realize welding cast isnt like welding mild or stainless steel, and that the person doing the repair needs to be VERY skilled at his craft to get it right.
Whatcha all think?
Daniel
