Ok. I got the tranny hooked up to the driveshaft and the engine. Engine idling I put in about 8-9 quarts of ATF. Put it in Neutral to let it slosh around some more. Check the ATF, normal. Put it into Drive and Reverse, nothing. No movement whatsoever. Could this be from the lack of a TV cable, the right rear wheel being locked up, or because the converter might be shot? No load seemed to be on the engine. Increased RPM's dramatically but nothing.
Anything?
