My NV4500 swap adventure!
Postby Jeep-hauler » Fri Aug 01, 2008 5:18 pm
2muchtq wrote:If anyone is looking for a nv4500 for our trucks I know where there is one for 1500. Its a 4x4 trans with our bellhousing. This is still on a pallet. Bought it new a couple years ago and never swapped it in. So 0 miles. (thought he chunked the getrag.... found out the rear end wasn't as strong as he thought)
Located in Snohomish, Washington.
Again... dont know if its a decent price, but its there.
If its a brand new trans, that's a good deal. If its used, not so much.
Bgbubbabrn might be looking for one though.
'51 Power Wagon VE Cummins project.
'92 W250 -Got it cheap, it runs, it's ugly, it's a parts truck
'93 W250 -tweaked pump, 4" exhaust, NV 4500HD 5-speed. Jeep tow rig, daily driver. Sold.
Jeep-hauler
Postby 2muchtq » Fri Aug 01, 2008 6:40 pm
Its brand new. 0 miles.
He might even come down some.... I'd have to arm wrestle a bit.
2muchtq
Postby cummins king » Fri Aug 01, 2008 7:21 pm
Nice job, looks really good
Could you post a picture of the truck
93 4X4 auto
cummins king
Postby Jeep-hauler » Fri Aug 01, 2008 10:45 pm
cummins king wrote:Nice job, looks really good
Thanks, and here you go:
Jeep-hauler
Postby roxxx » Tue Aug 05, 2008 4:47 pm
AHHH crap I dont think you should have being allowed to post that set of pictures. you must have stock in the tranny company :lol:
I had just convinced myself to rebuild the old getrag now i am hooped
Ohhh Nice work and Good Pictures Outstanding finishing too very clean work
1992 4x4 Reg cab LE 5 speed
4 Inch lift
Bilsteins shocks 5125
VE moderately molested
Dana 80
ultra wheel rims Type 164
ASA pipe BHAF 19037
Outerwears prefilter
A A nv4500
roxxx
Postby Jeep-hauler » Wed Aug 06, 2008 7:16 am
roxxx wrote:AHHH crap I dont think you should have being allowed to post that set of pictures. you must have stock in the tranny company :lol:
I don't think that Getrags are bad, I just thought I could change mine out for less money. In the end it did cost me a little more than just rebuilding the Getrag. But I'm very happy with the end result.
Jeep-hauler
Postby roxxx » Wed Aug 06, 2008 8:41 am
Dont get me wrong i think they are Good trans to but you just made it look so darn puuuurrrddddyyy. I have being chasing a good nv 4500 for a while most of what I find are punched so I gave up and figured I would just rebiuld the getrag. BUT oHHHH no you had to post thooose pictures!!! now the green Eye of jealousy has reared its ugly head ... I think i need to rethink the nv 4500 swap ;-) hey how high is your lift ???
4 Inch lift
Dana 80
ASA pipe BHAF 19037
A A nv4500
roxxx
Postby Jeep-hauler » Wed Aug 06, 2008 3:22 pm
roxxx wrote: hey how high is your lift ???
I don't really know. 4 to 6 inches I would guess.
Jeep-hauler
Postby VEfreak » Mon Aug 25, 2008 9:24 pm
I've been looking into swapping a nv4500 into my reg cab auto 4x4. If i got it out of a reg cab 2500 or 3500 would i need to swap drive shafts? Would i have to use the flywheel and clutch set up off a second gen? What do i really need to know to do this swap?
I AM ZUES DAMNIT
VEfreak
Postby Jeep-hauler » Wed Aug 27, 2008 9:53 am
VEfreak wrote:I've been looking into swapping a nv4500 into my reg cab auto 4x4. If i got it out of a reg cab 2500 or 3500 would i need to swap drive shafts? Would i have to use the flywheel and clutch set up off a second gen? What do i really need to know to do this swap?
I don't know about driveshaft length differences between autos and manual trucks, and 2nd gens use a different transfercase that drops on the wrong side for our trucks. You can still use the 2nd gen trans though, just be sure to get the bellhousing, clutch hydraulics, and engine to bellhousing adapter plate. The clutches are the same. You will need to bolt up your existing NP205 to the NV4500. 1st gen manuals have a 29 spline t-case input, not sure about the autos.
The other option is using the "Advance Adapters" conversion bellhousing. With this bellhousing you can use 1st gen hydraulics, and it bolts up to your existing engine adapter. You also have to shorten the front bearing cover(supports the throwout bearing too) snout to make this conversion work. Its pretty straight forward.
Good luck :D
Jeep-hauler
Postby coalminer1022 » Sun Dec 07, 2008 8:15 pm
my truck is a 92 auto, would i need the parts from NV 4500?
coalminer1022
