CLUTCH
CLUTCH
Postby EARLBURNER » Wed Aug 13, 2008 9:09 am
What is the best clutch for the getrag 360? My cummins will have approx. 300hp. Ive heard bout the sachs where can i find one and will it hold up? Towing will be very light but the truck will be in a 77 chevy with 10 inch lift and 42" tires.
EARLBURNER
Postby Jeep-hauler » Wed Aug 13, 2008 9:56 am
Check out a South Bend Con-O if your less than 350 HP. I like mine so far, just broke it in. Some guys on here like Valair clutches too. Sachs is the OEM clutch I believe.
Check out this thread: http://1stgen.org/viewtopic.php?t=2009
'51 Power Wagon VE Cummins project.
'92 W250 -Got it cheap, it runs, it's ugly, it's a parts truck
'93 W250 -tweaked pump, 4" exhaust, NV 4500HD 5-speed. Jeep tow rig, daily driver. Sold.
Jeep-hauler
Postby gear jammer 91" » Wed Aug 20, 2008 9:03 pm
I have the valair organic/feramic and I am very pleased with it. I have also heard good stuff about luk clutches, witch would be a direct replacement like the sachs. If you go with a south bend or a valair make sure you get a 13".
Check out the thread "Aftermarket clutch" it's got some good opinions.
01 LB7
gear jammer 91"
Postby CumminsPride » Thu Aug 21, 2008 5:36 am
We just put a 12 1/4" Valair 3800# 550HP/Ceramic kevlar hybrid in my buddies 97. His pump is nearly maxed, to the piont his wife doesn't have to watch the pyro, and they tow 14k all the time. AWESOME CLUTCH!!
06 3500 AT Mega Cab SRW 4X4
CumminsPride
Postby railhor5.9 » Thu Aug 21, 2008 1:37 pm
i love my valair its a 4 paddle clutch very sensitive tho... but it holds real good
1993 d250,single cab short bed, sbc, 175hp p-pumped,4kgsk,370's, fass 150. hx35
1997 2500 4x4 , 913,191's,3kgsk,5x16, 3rd gen dubs.
railhor5.9
Postby dpuckett » Fri Aug 22, 2008 1:32 pm
I have an organic Valair in my W350. Nice clutch. I picked it up cheap, and it turned out to be good. Smooth engagement, holds 250hp or so well. It is a 13" clutch.
The stock clutch is a 13". Going to ANY 12-1/4" is a serious step backwards. You couldnt GIVE me a LuK clutch.
Daniel
Users browsing this forum: No registered users and 88 guests
