Pull the pan and found metal
Postby VEfreak » Sat Sep 20, 2008 5:01 pm
Check my tranny fluid the other day, seemed kinda crispy so i decided to change it and the filter. Drained the tranny, which was sweet and easy since my pan has a drain plug. pulled the pan and found the filter screen was ripped, i didn't like that. But what i found in the pan was even more disturbing. About a table spoon in a half of metal sludge, with some shavings. Not many shavings, only some. But that seems like an excessive amount of sludge, should i go into red alert?
Also i would like to know if the front and rear bands are the same, and if a rigid carbon fiber intermediate band is a good choice. It's 10% wider than stock. I can't really make sense of PATC. they have flex bands, rigid bands, front bands, and low/reverse bands. as far as i know, there are only two bands in these trannies.
I AM ZUES DAMNIT
VEfreak
Postby mprmn08 » Sat Sep 20, 2008 5:44 pm
if its a new tranny and the first time you've had the pan off since then thats normal. the ripped filter may not be good as some may have made its way around but the shavings arent necessarily a bad thing.
mprmn08
Postby VEfreak » Sun Sep 21, 2008 8:03 am
thanks, that takes some stress off of me. And i found a good article on bands and all the different lingo for em, so i got that figured out now too.
I AM ZUES DAMNIT
VEfreak
Postby nojackwayne » Mon Sep 22, 2008 7:26 pm
VEfreak wrote:thanks, that takes some stress off of me. And i found a good article on bands and all the different lingo for em, so i got that figured out now too.
Do you have link for that article?
92 W250 IC reg auto. H1C w/16cm, boost/pyro/fp, 366spring, DennyT stg II, pump tweaks, k&n, custom bumper, custom dp w/4" exhuast
01 C&C 3500 4x4 man. stock for now
08 C&C 5500 4x4 auto. egr&dpf fell off
nojackwayne
Postby VEfreak » Tue Sep 23, 2008 9:17 pm
I AM ZUES DAMNIT
VEfreak
Postby VEfreak » Sat Sep 27, 2008 11:30 am
i was looking at the band adjusters. They're not a hex head, they're square. Is there some kind of specialty tool used to adjust them?
I AM ZUES DAMNIT
VEfreak
Postby PToombs » Sat Sep 27, 2008 5:09 pm
12 point socket usually works good. ;)
Postby VEfreak » Sat Sep 27, 2008 11:18 pm
thanks
I AM ZUES DAMNIT
VEfreak
