Gasser and Diesel tranny question
Postby RSWORDS » Sat Sep 27, 2008 12:23 pm
What is the internal difference between a diesel 727 and a gasser 727? Cold yuo get a 727 from a dragracer say and put it into your truck easily?
RSWORDS
Postby RSWORDS » Sun Sep 28, 2008 10:30 am
nothing?
RSWORDS
Postby Ace » Sun Sep 28, 2008 1:47 pm
I don't know for sure, but the diesel and motorhome 727s probably have a 4-pinion planetary, lower 1st gear, more clutches, etc.
I'm not that well versed on the transmissions, never even been inside one.
Ace
Postby Richie O » Sun Sep 28, 2008 5:15 pm
I don't know much but will try. The case is different, the valve body must be different due to low rpm shifts compared to gassers. Philip help me out here.
Postby RSWORDS » Sun Sep 28, 2008 5:36 pm
The reason I'm asking is I have a guy on my tool route that has a spare 727 out his drag car. VERY built and he will let it go cheap.
RSWORDS
Postby oldestof11 » Tue Sep 30, 2008 1:31 pm
Differences are the casing (diesel is stronger and has more meat on it) and the internal governor for the gear changing it different.....
THat is all I know.
Postby RSWORDS » Thu Oct 09, 2008 5:12 pm
If you go full manual valve body two questions....
1. Can you use one from a gasser? Is the difference from the gasser to the diesel just the shift points and how it is set up? Wont a full manual do away with all this?
2. Wont a full manual ZVB do away with the govoner or at least the function.... Not that it matters we can just leave the stock on in.
RSWORDS
Postby mprmn08 » Fri Oct 10, 2008 7:00 am
the shift points are based off of the kickdown cable and tv cable adjustment. i can take a gas trans and make it shift at 1500 rpm if you want me to. its not the VB or anything. At the most you may have more clutches STOCK in a diesel vs. gas one or a steel planetary insteand of alum. hope that helps and good luck.
mprmn08
Postby txs » Sun Oct 12, 2008 12:58 pm
All 727s have had the same ratio plannetaries since inception in 1962. The case is unique to the cummins, The only other difference between it and a heavy duty gasser is extra heavy governor weights, larger teeth but less of them on the pump rotors, and on the early cummins trans a larger drilled lube passage in the pump casting. After a while they got tired of keeping track of 2 pump part # they just drilled them all out. I'd have to look up the exact date but at a certain point in time they quit making the 3 pinion front carriers and just built them all with 4 pinion, cept for cummins tranny 5 pin aluminum front carrier, untill the 47rh-618 came out which had the 5 pinion steel.
txs
Postby txs » Sun Oct 12, 2008 1:03 pm
RS, the full manual vb will not use the governor to contol shifts but you will get tired of fishing around with the column mounted stick on every shift, now the antique cable shift (push button) 727s were more fun when used with full manual vb.
txs
Postby randyswelding » Wed Oct 15, 2008 4:27 pm
well thanks for my question i also had,i got a tci towmaster from my 85 and my 92s cummins motor is goin in it,besides the case meat and the other thing what else is there thats diffrent.this tranny barly has 10000miles on it and dont want it to go to waste(unless my dad takes it and the motor for HIS 61 ford)
'92 D350 cab and chassy,pump turned up with 1/8 timin,coaltriann 6x16 sticks,htt manifold,asa intake cooler tubez,south bend 13" clutch rebuilt G360,ps cooler,industrial super 62 phat shaft turbo,weldin bed.
12 Chevy 3500ltz lifted, deleted, and bed with sae 300 ss hood for new rig
randyswelding
Postby RSWORDS » Sun Nov 23, 2008 7:13 pm
So the general consesus is that I can take all the good stuff out the gasser drag tranny and swap them into the diesel case. And I can use the gasser manual VB in my diesel tranny.
RSWORDS
Users browsing this forum: No registered users and 92 guests
