getrag oil?
getrag oil?
Postby clubcustoms » Mon Nov 03, 2008 11:48 am
i have a getrag in a 1990 w-350 and all thry threads i read are saying to overfill it by one quart through the shifter hole....what is the best oil to fill it with? The guy i bought it from said he just put synthetic in it but not what type of synthetic. some say fill it with ATF...some say engine oil...some say gear oil....??????
clubcustoms
Whatever you do, don't use gear oil.
Postby Ace » Mon Nov 03, 2008 1:02 pm
The best thing for it is a synchromesh MTF. These fluids came out later, and will provide much better performance and protection. I use Royal Purple Synchromax in mine. There's any number of them available out there now.
It's easier to use a PTO bolt hole to overfill.
Ace
Postby bgilbert » Mon Nov 03, 2008 2:25 pm
You'll find the most recommended and used lube is Mobil One 5w30 synthetic engine oil.
Bill Gilbert
bgilbert
Postby PToombs » Mon Nov 03, 2008 6:09 pm
I run regular 15-40 in mine, but I don't run it in the winter either.
On the overfill, I put a street ell in the check hole, then a nipple and a cap to raise the fill point. I can just pour the oil in now.
I also welded a piece of rod in the cap, for a dipstick.
Postby GLHS » Sun Nov 23, 2008 7:36 am
I used to run Mobil 1 5w or 10w 30 but after going to Redline MTL, I won't be going back to Mobil.
My other recomendation is same as Ace's; Syncromax.
I now always fill it through the top PTO hole. Adds at least 1 and possibly 2 more quarts.
GLHS
Postby nooblet » Tue Nov 25, 2008 12:03 am
I run the same 15-40 in my engine, tranny, and tcase, makes oil changes easier!
I fill mine with a pump through the top bolt of the PTO cover. Removing the shifter is a major PITA for me. Most people don't have as much trouble with it from what i gather, but in the 3 times I have done it it took me forever. I try to avoid that at all costs.
Chris
nooblet
