Hey folks, I hope everyone is having restful holidays (if there is such a thing).
I've run into a bit of an issue with my heap's transmission. I'm wanting to correct it (them) before the trans toasts itself . . . . if it hasn't already.
Not quite a year and a halve ago, I rebuilt my A518 non lock-up transmission including Alto Red/Koleen Steels and ~
- The rear clutch-pack (forward). Went from an OEM of four clutches and steels to five of each.
- The front clutch-pack (direct) There I went from an OEM of four clutches and steels to six of each.
- The front band was changed to a solid type.
- A 4.2 to 1 ratio lever for the front band.
- An upgraded overdrive piston retainer.
- A new rear band.
- Tricked out multiple seal servos.
- Upgraded the OD direct clutch to 23 single-sided friction elements.
- Upgraded the OD spring and it's associated plate.
- The OD clutch itself was upgraded to six clutches and steels.
- A full TransGo kit.
- Suncoast converter.
- A supplemental fan assisted cooler with in-line spin-on filter.
- Bunch of other crap.
It's been doing well till recently when I installed twins (HT3B/HX35 hybrid). Prior to the twins I was running about 395HP / 725ft/lbs (#2/uncorrected). With that (and a little W/M) I could make a pass at the local tracks and not have any issues with the trans.
Adding the twins has taken me to about 406HP / 840ft/lbs (#2/uncorrected). Turning on the not yet tuned for the twins W/M takes it to about 405HP / 900ft/lbs (uncorrected).
With that the trans is slipping on engagement of the gears during a full power pass (13.90 @ 97.78 in the quarter).
I've stopped racing the mess till I can sort out and correct the slip as I don't want to ruin things.
- Would I be correct in thinking that I can raise the hydraulic pressures and stop the slipping? If I recall the TransGo install, in setting the pressure regulator, I turned the screws in three turns from flush out of a possible maximum of five turns (assuming more turns in means a higher pressure).
- Is it possible I should have used the 5 to 1 band lever instead of the 4.2 to 1?
What'cha reckon?
Thanks, David.
