Which Flywheel????
Which Flywheel????
Postby MudSlinger79 » Wed Jan 21, 2009 8:26 am
I have a 93 12v and I'm putting a nv4500 behind it do I need a 2nd gen flywheel or will my 1st gen one work?
93 Ford, 1st Gen Cummins, 66/71/14 S-300, New Era 435 Sticks ,Pump Cranked, denny 2 fuel pin, afc MIA, 3200 spring. Sitting on 5 Ton Rockwells With 63" Rice And Canes. More To Come!!
MudSlinger79
Postby dpuckett » Wed Jan 21, 2009 5:10 pm
Your 1stGen flywheel should work, as will your good stock Sachs clutch- input shafts are the same size and spline count.
Dan
Postby MudSlinger79 » Wed Jan 21, 2009 8:51 pm
Thanks
MudSlinger79
Return to Transmission
