Ace wrote:The MTG is GL4 gearbox oil. Severe Gear is a GL5 hypoid gear oil for diffs and such. I believe the 205 is just a straight-cut gearbox. In all reality they are not that much different except for whatever EP formulation Amsoil uses to make Severe Gear GL-5 rated - probably the sasme base stock. You just don't need the GL5 rated fluid in a transfer case and it's probably more expensive.
dazedandconfused wrote:Do the bolt in Sprag. I've tore out three of them when I had my old truck together. I plan on doing one when I go threw my 47rh.
dazedandconfused wrote:Hope you have better luck then me. What all did he do to it?
Andy
aspoonhour wrote:Thanks for the updates!
FWIW...I think I'm going to with an NV4500 in my RC...I will have a complete 4x4 727 available...Mind you...It in pieces, but all there.
