Guess that Axle (1st gen axle upgrade)
Postby pulltilbroke » Tue May 12, 2009 12:17 am
Check out what stillsmokin and me are workin on, can you guess what axle it is?
These have been used in gas pull trucks in our area for quite a while with a lot of good results in stock form, This one has been altered quite a bit using parts from another common rear
MMMM Beefy
Postby Firstgen1 » Tue May 12, 2009 3:56 am
stumped me, the drums look like off of a dana 60
1993 w250 pin ground, 3 turns on fuel screw, starwheel maxed, custom intake,4in exhaust, guages, 16cm housing, piston lift pump, dtt converter, shiftkit, 35 psi of boost
Firstgen1
Postby txs » Tue May 12, 2009 5:27 am
looks like a 14 bolt
txs
Postby KTA » Tue May 12, 2009 6:13 am
Looks like a 102 Rockwell.
Postby RSWORDS » Tue May 12, 2009 6:25 am
Your not gonna have a problem in your class pulling with a non 1-ton or lower axle will you? Or is it just brush pulls?
RSWORDS
Postby pulltilbroke » Tue May 12, 2009 11:20 am
The beauty of this axle is its out of 3/4 and 1 ton trucks so we'll still be able to pull at any hook this axle has some serios beef, Its got a lot of advantages over a 70 and even an 80, 2" pinion, 3 pinion bearings, pinion support, and a load bolt to resist ring gear deflection, Think Semi truck hardware for a pickup :D
txs your gettin warmer
Any more guesses
Postby RumbleFish » Tue May 12, 2009 12:12 pm
eaton
Postby 93_Fummins » Tue May 12, 2009 12:41 pm
RumbleFish wrote:eaton
Along with RumbleFish...
It looks kind of like the 14 bolt Eaton that was used before the Corporate 14 bolt...but that's just my guess
93_Fummins
Postby pulltilbroke » Tue May 12, 2009 1:03 pm
Bingo 93fummins
It is an GM HO72 used from 47-72 in GM 3/4 and 1 ton trucks
Alot of the 14b parts will fit in the HO72 carrier to make a pretty killer axle
Postby IowaCummins » Tue May 12, 2009 2:07 pm
holy crap man thats like a ford 9" on steroids! looks beefier than some of the currie 9s. lookin good man!
IowaCummins
Postby pulltilbroke » Tue May 12, 2009 2:32 pm
Exactly, if you break it in the light class you still got time to swap out the pig before the heavy class :D if you brought a spare with ya
and with the steel housing you dont have to worry about twisting the centersection out of the axle tubes
Postby KTA » Tue May 12, 2009 10:15 pm
Will the 14 bolt ring and pinions work? If not what kind of gear ratios are available?
Postby pulltilbroke » Tue May 12, 2009 11:03 pm
KTA wrote:Will the 14 bolt ring and pinions work? If not what kind of gear ratios are available?
No they are not interchangable
The available ratios are 4.10,4.57,5.13 and I think thats it, there might be 1 lower gearset available, but the 4.57s are the most common
The drawback is there are no aftermarket gearsets available for this rear so you got to find good used ones
Heres a pic of a 14b (top) and a HO72 pinion for comparison
The 14b pinion is the same size as a D80
Postby RSWORDS » Wed May 13, 2009 12:47 pm
pulltilbroke wrote:The beauty of this axle is its out of 3/4 and 1 ton trucks so we'll still be able to pull at any hook this axle has some serios beef, Its got a lot of advantages over a 70 and even an 80, 2" pinion, 3 pinion bearings, pinion support, and a load bolt to resist ring gear deflection, Think Semi truck hardware for a pickup :D
Any more guesses
AWESOME!
What 3/4 and 1 tons did they come in?
EDIT: Nevermind...Just read teh rest teh thread. :lol:
RSWORDS
Postby pulltilbroke » Wed May 13, 2009 1:48 pm
Another thing to keep in mind is the 1410 yoke for this rear is 200$ :shock:
And pinion bearings are real spendy too so find a good used rear with low miles
