help!!!!! auto trans. ??
Postby fjkfta » Sun Jun 24, 2007 12:08 pm
I have a 93 w250 auto. The extension housing cracked recently when the wife was driving and it came to a stop literally. So heres the problem i replaced the extension housing and now the truck goes in 1st gearf and reverse with no slippage but will not shift out of first gear. Any comments will be greatly appreaciated as the truck has been down for 2mos. and i need her back!!!! :cry: :cry:
93' w250 some pump mods but not enough. need guages before any more.
fjkfta
Postby sdstriper » Sun Jun 24, 2007 4:15 pm
Check your TV cable adjustment, as well as the rest of the linkage.
http://dens-site.net/Dodge_CTD/Kickdown_Adjustment/
I doubt it but it could be the Throttle Valve stuck in it's bore. Have to drop the pan and visually check for the obvious broken this or that...
Do you have a Factory Service Manual? That is the best source of trans. service and rebuild info.
sdstriper
Postby fjkfta » Sun Jun 24, 2007 6:29 pm
I will check on that but i dont know what would of changed sinse i didnt drop the tranny just the extension housing and the transfer case. Thanks for the replie though i will look at it tommorow cause its dark outside right know.
fjkfta
Postby Philip » Sun Jun 24, 2007 9:26 pm
Check governor pressures. If the governor sticks in the open position it can cause no upshifts or high RPM upshifts only.
It is located in the tail housing area also.
Postby fjkfta » Mon Jun 25, 2007 3:29 pm
how do you go about checking the pressure is there a line to tap into. Sorry for being so unknowlageble but i have never had to work on a auto tranny.
fjkfta
Postby sdstriper » Mon Jun 25, 2007 7:54 pm
There's a photo in this thread for reference. I'll look at my manuals for specs if I get a chance this weekend, been out of town lately with very little time. Maybe someone else can chime in with the pressure specs...
http://www.dieseltruckresource.com/dev/ ... p?t=156988
sdstriper
Postby Philip » Mon Jun 25, 2007 9:06 pm
Port number 4 in that post is the governor port. Hook a gage into it. Put the truck on jack stands.
Start the engine and put the trans in drive. With the truck idleing in drive the rear wheels not turning you should show 0 to 1.5 PSI.
Release the bakes and apply slow smooth throttle. You should see a steady rise in PSI as the speed increases.
If your governor is working correctly then time to head into the valve body. If you don't have a FSM I would recommend getting one. Now.
Postby fjkfta » Tue Jun 26, 2007 7:13 pm
Thanks for all the help i am on the road so it will be this weekend befoere i get to test the pressure. Yes i would like a fsm but dont have the cash right now if you know what i mean. If the pressure are bad what could be the problem ??maybe the pump in the tranny burnt up when the old lady broke down?
fjkfta
Postby Philip » Tue Jun 26, 2007 9:03 pm
It could be about anything. The first question I would have is did you use a gasket on the tail housing or RTV?
If you used RTV then most likely you have a ball of it down in the governor passages.
Postby fjkfta » Tue Jun 26, 2007 9:39 pm
i used rtv cause dodge by my house was taking to long on the gasket been over 2wks they keep saying its in transit yea right. If it is a ball in the passage can it be removed without pulling the extension housing again it was a PITA
fjkfta
Postby Philip » Wed Jun 27, 2007 8:48 pm
Do the governor pressure test and lets see what it is doing and go from there.
Postby fjkfta » Wed Jun 27, 2007 9:04 pm
Thats a big 10-4 when i get back in yown thats #1 on the list and i will keep yall posted.
fjkfta
