peobryant wrote: I'm not even sure what the fusable links are
This is where the fusible links are, AKA "The Duckbill". It's right around the grid heater relay area on your front fender. As you can see, there ain't many of mine still in use.
Tacoclaw wrote:peobryant wrote: I'm not even sure what the fusable links are
Tacoclaw wrote:That small orange one is your battery feed to your key switch. Mine is also wired directly to the battery, I just stuck a blade fuse inline. The big green one is the fuse for your alternator feed back into your battery.
