Short in my factory gauge cluster...any help?
Postby 93DodgeCummins » Fri May 25, 2012 10:41 pm
The other night i went to turn my lights on and my gauges didnt light up. So i checked the fuse and it was blown. I so put in another fuse and turned my lights on and it blew it instantly... Is there any common spots that i can check without taking the dash apart on a search? Any ideas?
93DodgeCummins
Re: Short in my factory gauge cluster...any help?
Postby 93DodgeCummins » Sun May 27, 2012 1:54 pm
figured it out. its was my rpm gauge
93DodgeCummins
Postby Hansen01 » Sun May 27, 2012 6:13 pm
Glad you figured it out 8)
Under construction...
Hansen01
Return to Electrical
