Electrical stresses me right out !
Would anyone know where to start looking ?
PToombs wrote:Follow the KISS theory. Start with the fuses. Usually if the fuse goes you lose the dash lights too.
I bet the light switch crapped out.
but they do shut off every now and then when I try the dimmer. If the weather clears this weekend I'm gonna dig into the harness. I may hane a loose connection somewhere because when I did tear the truck apart everything came off !PJ 3 wrote:PToombs wrote:Follow the KISS theory. Start with the fuses. Usually if the fuse goes you lose the dash lights too.
I have dash lights.......
PToombs wrote:Pull the light switch and look at the plug. If it's melted, that's the culprit.
