fuel Level Gauge
fuel Level Gauge
Postby lectro_static » Fri Dec 11, 2009 10:16 am
My fuel gauge has not worked since Ive owned my truck, right now I just fill up every 200 miles to be safe. I have no idea whats wrong with it, I checked grounds and it seems good. Is there a common issue with them?
weeping head gasket
4" straight pipe
M&H M3 fuel pin
M&H Dynamic Timing Advance
366 spring
Auto Meter EGT and Boost
lectro_static
Postby Ace » Fri Dec 11, 2009 10:45 am
The senders go flaky either because it gets gummed up/dirty and/or loses tension on the arm that holds it against the electrical contact patch in the sending unit.
Postby lectro_static » Fri Dec 11, 2009 10:49 am
Well guess out it comes and a fuel system upgrade is on the way, I hate dropping fuel tanks
weeping head gasket
4" straight pipe
M&H M3 fuel pin
366 spring
lectro_static
Re: fuel Level Gauge
Postby madabi81@aol.com » Wed Mar 24, 2010 6:22 am
my fuel gauge works intermittenly, what causes this? is it just like earlier mentioned? gummed and wore out?
madabi81@aol.com
Postby PToombs » Wed Mar 24, 2010 5:58 pm
Probably wore out. I can't believe it would get too gummed up, riding in fuel all day. The contact on the arm rides on some fine wires wrapped around a non conductive piece of stuff. The wires wear, the bushing on the arm gets bad and the arm wobbles off the wires, or it loses tension.
Postby huntinguy » Wed Mar 24, 2010 6:35 pm
Mine only shows 3/4 tank when I fill it up and it don't run out tell it gets to the "E". What would that be?
89 non-I/C W-250, flatbed. 4" turbo back. Ground fuel pin, AFC tuning.
huntinguy
Postby dpuckett » Fri Mar 26, 2010 12:25 pm
ACtually, if you drive it about 300mi, you should be ok dropping the tank. I've done it a few times, and it's easier with an empty tank.
DP
Postby delinquent » Fri Mar 26, 2010 9:54 pm
whole lot easier to remove 8 bolts and the bed than to drop a tank, taking a risk on breaking a $30 strap, being a royal pita. I can remove a bed in about 10 minutes tops.
delinquent
Postby FRadisi » Sat Mar 27, 2010 9:11 pm
The fuel gauge on my dad's ramcharger is also screwy, the first half of the tank is from above F to F, and the other half is from F to E.
FRadisi
Return to Electrical
Users browsing this forum: No registered users and 69 guests
