OK..so I know there has been other threads on this,but I'm really not finding a answer...so heres my problem. Many of you may know that I have converted a 81 crew cab with a 92 cummins 5spd...so everything got tranferred over.
MY battery is not getting charged... First off I had the alternator tested and the battery...checked out fine, both are good and working.
So how Do I know if the crank sensor is bad or not?
My AC and the CC are not plug in...would this cause a problem?
I have read about installing a voltage regulator...DO I NEED SOME KIND of Relay? IF so exactly what do I need and how do I wire up the relay?
How do I know if the problem is in the PCM or not? If the problem is not in there will it hurt to hook up the external regulator?
Thanks
