wait to start issues
Postby odessacowboy » Tue Feb 02, 2010 5:21 pm
roll the key to the run position, wait to start light is off...start the engine, and the wait to start light comes on and stays on...i had a charging problem also, but a new alternator fixxed that problem, charging the battery up, out of the truck, now...any input appreciated... 1993...
1993 D 350 LE...4" straight..guages---2004 2500 4x4..5"..bullydog triple dog downloader..
odessacowboy
Postby RSWORDS » Tue Feb 02, 2010 8:15 pm
Here is the FSM section for Grid heater operation and diag. Its easier to open it up and download the .pdf file then try to read it online. I hope it helps!
http://www.dieselbombers.com/1st-genera ... eater.html
RSWORDS
Postby odessacowboy » Wed Feb 03, 2010 6:50 pm
thanx for the link...just not real electrically inclined...poked around with my testlight, made comparisons to my 1990 work truck, didn't find anything...light still doesn't come on till after the engine is running...stays on solid, no blinking till i shut it down again...i have 3 relays on the fenderwell, by the solinoids, 2 of the same, and the other one is a different plug, i swapped the 2 and that didn't change anything either...i guess i'll disconnect the 2 wires at the manifold solinoid and tape them and see what that does...i don't want to juryrig anything, just want to see that light off...
odessacowboy
Postby odessacowboy » Wed Feb 03, 2010 8:38 pm
well, disconnected the 2 wires at the heater grid solinoid, and the same thing...going to sleep frustrated...
odessacowboy
Postby odessacowboy » Thu Feb 04, 2010 8:28 pm
should i just disconnect it and leave it...been reading some of you do without any problems...undecided...
odessacowboy
Postby 1STGENFARMBOY » Thu Feb 04, 2010 8:46 pm
If you do leave them off you should take off the grid all together for a little more air, you shouldn't need it living way down south.
Postby odessacowboy » Sat Feb 06, 2010 7:41 pm
back on it in the a.m....been busy moving into new house...my old battery was almost 3 years old, and a bit smaller than i'd like...pikked up a new 1000 cca interstate 2 day and some new cable ends...thanx...
odessacowboy
Postby new dad » Sat Feb 06, 2010 8:41 pm
i disconnected my grid heater and took the fuse out so the light would stay off :grin:
98 3500, 5sp, dpp 90's, 10 plate, 4k springs, sb fe. totalled
90 d250 727, stock for now, coming soon: trans swap from a '95 2nd gen, 366 spring, m&h m5, custom crossover plumbed for a little w/m and n2o
new dad
Re: wait to start issues
Postby odessacowboy » Tue Feb 16, 2010 9:57 pm
installed the new battery, 950 cca, new terminals, redid the other connections on the battery...also new alternator last week...disconnected the heater grid,putting up with looking at the wait to start light while i'm driving...drove to brookesville the other afternoon, bout an hour away, and on the way home the amp guage dropped way down and all my lights got weaker and weaker...was glad to get home...so,no charging, again, no seperate voltage regulator on the firewall...charged up the battery with a charger,took about about 24 hours for full charge...kinda not knowing which direction to go now...
odessacowboy
Postby Ace » Wed Feb 17, 2010 8:19 am
Might want to check the crank sensor. It won't charge if the PCM is not getting a running signal from the crank sensor.
Postby odessacowboy » Fri Feb 19, 2010 10:01 pm
went by the alternator shop with the truck 2-day...had them put their guages on it, not charging...pulled off the new alt., he checked it and found nuthing wrong with it...then he checked the wires that hook to it, found no voltage coming through...so, i just bought an external voltage regulator from him for 15 bucks,he showed me how to wire it in,,took it home, not charging, wired it in, mounted it to the firewall, where one would normally mount...he told me that the internal voltage regulator is ran by the ecm, so by wiring in the new one the way i did, it's kinda tricking it into thinking it's charging, the electronic control module, hope i got all that right...anyway, charging good now. now i can get back to my wait to start issues...still have the heater grid unhooked...
odessacowboy
Postby odessacowboy » Tue Jun 15, 2010 8:53 pm
bad grounds were the culprit...chekked all i could find, cleaned, scraped, and wire brushed...all is good...o.d, a/c, and cruise control all working normal now...sure was missing my o.d...and my a.c...life is good...
odessacowboy
Return to Electrical
