led tail light problems
Postby dodge1stgen » Mon Sep 27, 2010 4:17 pm
I'm putting leds on my one flatbed,got the front lights finished and working can't figure out the back lights.The turn signals only work when the brake lights are on,brake lights dont work when running lights are on,running lights never work.I put load resistors on the front to get them flashing properly.Not much on wiring,hope its something simple I overlooked.Thanks Eric
93 250 ext cab p pump injectors 2 disk clutch 3'' charger nv 4500 retired
92 350 ext cab 5 spd 366 spring bd injectors hx 35 dana 80 flatbed
92 350 converter built trans bd fuel pin flatbed/dumpbed
dodge1stgen
Re: led tail light problems
Postby TRENDZ » Mon Sep 27, 2010 6:10 pm
White= ground
black= tail
red= stop/turn
91 d350 1/2" supply lines, 2nd gen lift pump, regulator, 366, screwed, homebrewed afc pin, linkage mods, ported head, ported ex manifold, 351ve electrically controlled, 3" boost tubes, 2nd gen I/C, 4" ex, goerand
TRENDZ
Postby dpuckett » Wed Sep 29, 2010 10:18 am
If you have standard bulbs in the front, the LEDs in back shouldnt change anything.
I'd start by checking and double checking my grounds.
DP
Return to Electrical
