by Ptothej » Mon Apr 26, 2010 9:02 pm
Ahhhh sorry! When you think you've covered all the info! Factory! Factory tach.. and more info I just realized, I believe at idle the tach is pretty bang on, it seems almost the higher I go the worse it is? And I stand corrrected, at 100k/hr Im just a hair over 2k.. now I know this thing hasnt been reved as high as Ive reved it, not saying I rev the sthi out of it, (stock governor spring), but shes never had unrestricted exhaust, and pump tweaks.. original owner, but maybe its only been reved to a certain point in its life, and is getting sticky, or something from being pushed past whats its read for the past 18 years? Ideas?
'92 W250, 5spd, reg. cab, 2" lift, 4" dp, 4"exhaust no muffler, smoke screw bottomed out, star wheel bottomed out, full power screw maxed, BD fuel pin, BD 16cm housing (30psi), K&N air filter with a modified factory air box
