by skilletky » Mon Oct 17, 2011 4:52 am
i had the same problem with only the headlights working, the black wire with yellow tracer is the marker lights power wire. my problem was were the wire spliced off and went to the cab lights down to the fire wall, pulled it apart and installed a butt connector. there is also a marker light relay (atleast there is on mine) that you may want to check.
