Wait to start missing and ignition switch?
Postby Erska » Wed May 25, 2011 10:05 am
Hi. I have a W-250 1990 5 spd 4x4 and previous owner has made some horrible changes like truck has separate starter switch on the dash which is just plugged from battery to the starter solenoid via fuse It starts turning engine without keys on the ignition lock. Original solenoid wire to the starter has been cut inside the engine bay.
Also my grid heaters dont work. There's no wait to start light . Ignition lock has to be in "on" mode to start because of the shut off solenoid.
If I try to start the truck normally and keep the key on the "start" position everything like radio and the fan goes off like they should.
But then I can also see "Water in the fuel" light. So I assume that works.
I also have Antilock and (P)Brake lights on.
They went off when I took battery cable off but they came back as soon I start moving the truck.
ALSO the fan switch is missing on the dash. It's on the high position all the time when I turn power on.
Any tips? HELP!?
Thanks! :alien:
Dodge W-250 6bt reg cab 5 spd 1990. Sold my ex Twin turbo 1998.5 and bought a W-250 :D
Erska
Re: Wait to start missing and ignition switch?
Postby Richie O » Wed May 25, 2011 3:16 pm
Welcome to the world of crappy wire hack jobs.
Postby ellis93 » Wed May 25, 2011 4:21 pm
Richie O wrote:Welcome to the world of crappy wire hack jobs.
What's that! You referring to Mopar :mrgreen:
Postby Erska » Thu May 26, 2011 12:38 pm
I know that. Thanks. Any tips or advices? :roll:
Erska
Postby Richie O » Fri May 27, 2011 6:40 pm
Take out the glove box and unplug the black box thats right behind it. That will get rid of the brake / abs lights. Its the abs controller.
Postby Erska » Sun May 29, 2011 7:24 am
Richie O wrote:Take out the glove box and unplug the black box thats right behind it. That will get rid of the brake / abs lights. Its the abs controller.
Ok Thanks :D That's "fixed" now. Next? Any tips for the grid heaters?
Also it worries me that my oil pressure light come on when I'll let the clutch without any throttle. Rpms do drop below the Idle. That might be it. But it wont stall and it only happens when the engine is warm... I donät think I noticed it before. Well I'll see what's going on when I'll install the mechanical oil pressure gauge along with the Glowshift boost-pyro-psi gauge and ISSpro rpm gauge.
Erska
Postby PToombs » Sun May 29, 2011 3:28 pm
Oil pressure is probably a bad sender. They are known to be weak.
Grid heaters, check the relays, see if they get power to activate, etc.
Postby Erska » Tue Jun 07, 2011 7:54 am
Now when our weather is very hot, the egine got little more warmer than usual and when I came back from highway and dropped the rpm's to the idle, the oil pressure light stayd on constantly on idle. After that I plugged in mechanical oil pressure gauge and it showed healthy 15-22psi at idle when very hot. Max oil pressure with rpm's 55psi when hot.. 8)
Erska
Postby Erska » Wed Nov 09, 2011 11:11 pm
Hey guys. I noticed I had bad bulb on the Wait to Start light. But Now it stays on for about 30secs and then starts flahing?
It flashes all the time. I have the service manual but I'm not sure did I understand it right. So if it flashes all the time the temp sensor could be bad or what? :|
Erska
Postby ahale2772 » Thu Nov 10, 2011 4:55 am
my oil pressure sender did that as well, flashed on when I let the rpms drop, ive never seen lower than 22 when very hot with a mecha guage hooked into the same spot. BUT im going to put the sender back on with a T at some point to act as a low pressure warning light
can you hear the grid heater relay work? it sould come one for about 10 seconds
Return to Electrical
