Got two batterys hooked up for winter
Postby Hansen01 » Tue Aug 23, 2011 8:15 pm
well, i got another battery hooked up today and this is the way i put it in there, yes i do need to get a battery box made :roll:
Under construction...
Hansen01
Re: Got two batterys hooked up for winter
Postby Tsbourne09 » Tue Aug 23, 2011 11:42 pm
ow that is awsome! great project to do! howd you do it?
Not On Yet: 60#VS
Tsbourne09
Postby Hansen01 » Wed Aug 24, 2011 5:40 am
i reused the original battery box and jus turned the batterys as you see in the picture, i did have to take the one support that comes from fender to what the batterys sit on and get rid of it to make room, but everythings still good and sturdy, as for hooking them together we jus made those 2 short red cables you see in the pic and hooked +to+ and -to-
depending on how tall yur batterys are you may be able to wedge them into the inside of the fender a bit farther, mine were to tall.
Hansen01
Postby Hansen01 » Wed Aug 24, 2011 5:42 am
i now have 1900 CCA and im hopeing that my truck will actually start this winter, affor if would make a quarter stroke and then die with a brand new battery, my thought is that i advanced the timing to far and im to laze to retard it :roll:
Hansen01
Postby Diesel » Fri Aug 26, 2011 8:31 pm
Wow I want that just because it looks good. So its essentially bolt in?
1991.5 D250 Intercooled A518
Diesel
Postby Hansen01 » Fri Aug 26, 2011 9:05 pm
or strap in :D but yea all i had to do was remove 2 bolts that held what i think is the battery base support which really isnt needed, cus mine is still just as solid as ever amd then set them sidways like i did, i also used for now a 2x4 :roll: to put in between the 1st battery and the front of the truck so it wouldnt rub against my headlight wires, look at my picture and about anyone could do it
Hansen01
Postby Diesel » Sat Aug 27, 2011 5:13 am
I have absolutely no need for that other than just wanting it. My truck starts with a half crank but more battery is better right?
Diesel
Postby Hansen01 » Sat Aug 27, 2011 5:30 am
yea, untill u gotta buy new ones,lol but i would still do it, you never want to be stranded somewhere when theres -20 degree wind chill :D
Hansen01
Postby Diesel » Sat Aug 27, 2011 9:42 am
Well Costco has some really cheap battery prices and long warranties :D :mrgreen:
Diesel
Postby Hansen01 » Sat Aug 27, 2011 10:59 pm
lol well then go for it! :D
Hansen01
Postby freedomisntfree » Wed Nov 16, 2011 5:39 pm
Hmm.. i tried sliding 2 interstates in there couldnt really get em in there, even if i did i didnt feel to confident with the weight of both batteries being on that one side. Im putting one on the other side tucked in the well where the stock filter used to be. And run some 2gauge cables. It looks good tho. Good pic. I would like to see some setups
freedomisntfree
Postby Hansen01 » Wed Nov 16, 2011 7:54 pm
i actually changed the directions of them, cus i put an intercooler in it and then one battery was in the way, so they are now parallel with the fenders, real tight fit, but it fits, and nothing is rubbing(put rubber so it wouldnt) :D
i did have to take the fender support rod off to make it work. my batterys may also be skinnier
also if anyone does it like me, put a chunk of wood or something between the battery and your light socket so it doesnt hit
Hansen01
Postby ahale2772 » Thu Nov 17, 2011 5:25 am
just my 2cents but, ive always found that a dual system likes 2 quality batterys better than 2 cheepo's, if you opt for the cheep ones 9 times out of ten one will eventually die, take out the other, and usually your alternator at the same time.
Postby CAJUN 93 » Thu Nov 17, 2011 8:10 am
actually 10 times out of 10 all batteries will eventually die. thats what they do. still on a dual battery system as one battery fails it puts more load on the existing good battery and to a point the alternator. just test them individually occasionally and replace as needed.
daryl
CAJUN 93
Postby ahale2772 » Thu Nov 17, 2011 8:13 am
I ment premature failure, due to crappy batterys
