3 in 1 glowshift
3 in 1 glowshift
Postby cummins32 » Thu Mar 22, 2012 3:09 pm
Can I use the 3 in 1 glowshift gauge ? It's about 150 for it, so It'd save me 80 bucks, or should I just buy the autometer boost and egt gauge ?
cummins32
Re: 3 in 1 glowshift
Postby BILTIT » Thu Mar 22, 2012 3:16 pm
Why couldnt you use it? I have one in mine.
Derek B.
BILTIT
Postby cummins32 » Thu Mar 22, 2012 3:19 pm
I wasn't sure if the years mattered or not,Thanks for the fast response haha Where did you mount yours at ?
Diamond eye 4 inch turbo back, Glowshift boost, egt, oil pressure,hx35 , 3200 rpm spring, full power screw 2 turns, denny T II fuel pin, Home made Cold air intake, Alto reds and tci TC in a 518, 5x12's from diesel auto power.
cummins32
Postby oldestof11 » Thu Mar 22, 2012 3:46 pm
I took the base plate on mine, cut a corner off, and bent it to form around my A-pillar low, just barely above the dash. Loved it being right there. I use the 2-sided sticky tape to mount it up.
Postby cummins32 » Thu Mar 22, 2012 3:55 pm
Ok sweet I'll have to try that
cummins32
Postby BILTIT » Thu Mar 22, 2012 4:17 pm
Right on the dash.
Derek B.
BILTIT
Postby Remps » Thu Mar 22, 2012 9:04 pm
My glowshift in the W250 is mounted on the steering column. Works good.
