Single wire alternator conversion
Postby m880cummins » Mon Jun 11, 2012 8:39 pm
Looking for some single wire alt info. I plan to do a little thread about it here once I figure out what I need.
I have the factory denso on it right now. I know that's a good alt and I hear they can be made into a single wire. My main holdups are cost and down time.
I know PA performance offers a single wire for $200 range but I want to know if there is an application I can look up at the parts store where I work etc.
Thanks
Charlie
SUNY Maritime Class of 2017!
m880cummins
Re: Single wire alternator conversion
Postby Diesel » Tue Jun 12, 2012 9:03 pm
*THE* GM single wire is P7127SE but that is for a vbelt configuration unless you swap pulleys. Its real cheap but there is no point in going away from the stock unit.
1991.5 D250 Intercooled A518
Diesel
Postby m880cummins » Wed Jun 13, 2012 9:03 pm
I can swap pulleys no problem. As long as the GM one has the same mounting configuration I will do it. I can get them cheap where I work as well.
Charlie
m880cummins
Postby dazedandconfused » Thu Jun 14, 2012 4:20 am
You can get that same alternator with a serpentine belt.
Postby ellis93 » Thu Jun 14, 2012 8:54 am
He'll have to use the factory alt pulley no matter what,few more groves than the replacement will have.
