intermittent tack
intermittent tack
Postby little doug » Thu Jul 12, 2012 9:40 pm
Hi All !
My early 91 has one of those ( dealer installed ? ) Mopar tachs. Here is the deal. If the weather is wet, it works great. If the weather is dry,it doesn't work. If it rained the day before or there was a heavy dew over night, it will work on my commute,but wont work when I start the truck later that day. I have had this truck almost two years and it has done the same thing the whole time. Kind of screwy huh ? Any ideas? :?
Doug
93 W250 LE extra cab, 5 speed,warn winch, tach,piro,boost gauges. Gov.spring and fuel pin... Play truck
-91 W350 LE reg cab chassis.exxxxtended 175"wb, banks intercooler,on board air ,5 speed,... Work truck
little doug
Re: intermittent tack
Postby ellis93 » Fri Jul 13, 2012 4:38 am
Sounds like the crank sensor is bad. When it doesn't work,take a water hose to it. Wet it and see
Postby little doug » Mon Jul 16, 2012 8:36 pm
Well, I haven't had any time to do much except spray the radiator with water. When I did the tach started working. So do you think the cps needs replaced or just adjusted ?
BTW ,Thanks for the idea !
Doug
little doug
